Iam having trouble with my 55hp johnson 1967.It starts,idles and runs fine.The problem is after 30 to 45 min. at wot it starts dogging down and dies. After a short cool down 5 to 15 min.the engine will restart.The shorter cool down the shorter the run time. I have replaced the water pump, thermastat and inspected cooling system also tested over heat sender and lite. All seem fine.Cylender head and exhust cover don't seem to over heat.The fly wheel gets so hot you can't touch it.I have replaced all ignition parts except points.Nothing seems to be rubbing,crank end play and seal are fine. I have been through the entire fuel system,it all checks out.What else is there?
