  #1
Old July 15th, 2001, 04:48 PM
LeShrum LeShrum is offline
Default Evinrude 60hp - won't crank no trim control
I just bought a 1988 Eagle 351 with an Evinrude 60hp outboard (don't know the year of the outboard). The trim control stopped working so I can't tilt the engine up or down, and the engine will not crank. The battery is fine, the lights and the bilge work fine. This happened while the motor was running. The guage that shows the trim of the engine, all of a sudden looked like I was raising the engine...when I tried to adjust up the engine up or down, it wouldn't move, and couldn't hear the small whine that I normally hear when adjusting trim. So I shut the engine off so that I could hear better, and when I was sure that the engine was not lifting up, tried to restart the engine...wouldn't even turn over. I've been looking suspiciously at a solenoid at the back of the engine...it resides between the battery and the starter on the engine...if this were bad, would it affect the trim motor also? Is there a fuse or something that I should check...I was also thinking of buying your Volume II (seems to be the one for my year boat) book on Evinrudes, would that manual cover this type of topic?Thank you, I'm really very new to this...LeShrum
  #2
Old July 15th, 2001, 04:55 PM
clanton clanton is offline
Default Re: Evinrude 60hp - won't crank no trim control
Fuse on engine looks like real small red primer bulb. 20 amp short fuse. If your motor is great running motor, I would suggest you upgrade cooling system, I can give you numbers of SBs and waterpump pn .
  #3
Old July 15th, 2001, 04:56 PM
  #4
Old July 15th, 2001, 05:06 PM
Thank you, I think I saw what you described. Since it's still in the water at a friends dock, I'll have to go back to check it. I didn't want to start taking things apart with my limited knowledge (especially on the water). And the other info you offered...I'll look at anything that's sent my way, I'm that new to this. And yes...up to when it wouldn't restart, the engine ran very well...Again thank you...
  #5
Old July 19th, 2001, 05:48 AM
Clanton,You're a gem...thank you. Total cost of repair... $0.53 for the fuse with tax. It was exactly where you said it was.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Johnson 60hp 1971 Slow Crank (Solved: Bad NEW Battery) Zep-- Johnson & Evinrude Outboards 16 August 7th, 2006 09:18 PM
89 evinrude 60hp tilt and trim dusty221122 Johnson & Evinrude Outboards 2 October 31st, 2005 10:17 AM
Evinrude 115hp trim/crank problem crusader21 Johnson & Evinrude Outboards 4 June 23rd, 2005 02:35 PM
control box wiring for a 60hp johnson motor skippy401 Johnson & Evinrude Outboards 1 July 14th, 2003 06:48 PM
1990 60HP Evinrude power trim and tilt Stopped Working wippb Johnson & Evinrude Outboards 2 July 8th, 2003 04:16 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
