no spark on plugs
jberry
no spark on plugs
87- evinrude, no fire on plugs, engine turns over good.plz help thank you.
Joe Reeves
Re: no spark on plugs
Jberry.... If you can get at the back of the ignition switch easily, remove the black/yellow wire. If not easily, disconnect the black/yellow wire at the powerpack(s). Retry the ignition (spark) with the spark plugs removed. If you now have spark, replace the ignition switch.<br /><br />If still no spark, check the stator under the flywheel for cracks, portions of it melting down etc. If that stator is okay, the only item left is the powerpack. NOTE... it would help if we knew what horsepower engine you were speaking of.
