Re: Johnson 1974 throttle control housing
Thanks for the replies.<br /> Yes, the handle is off and warm up lever removed. There is by all accounts nothing holding it together. The Control housing is white all metal, with a black plastic top that is held together with 3 screws. One forward and two aft. These screws have been drilled out because of rust. The screws are mounted in a top to bottom configuration. Anyway, how is it held together. I know that the housing is mounted from the inside of the to the gunall. <br />I know on newer models 1982(made of plastic) they are two piece. <br /><br />Is there a cog that fits in a gear?<br />C-Ring holding the Throttle handle mechanism?<br /><br />Other than prying the thing off the gunall wall, it is the only way to get the thing off.<br /><br />BY THE WAY, REPLACING KEYSTART BECAUSE ANYONE COULD START IT WITH A SCREWDRIVER.
