1975 2cyl- finally got running good, and then started loosing rpm like starving for fuel.<br />I put a fuel pump on and carbs were recently rebuilt. After high rpm take off, looses power and then will not restart until next time completely cold. Second time I found tip of spark plug pressed against electrode and looks like it has been beaded by high temp explosion in cylinder. No hole in piston though. Could <br />this be a coil problem on that cylinder?
