Re: 85 johnson 115 shifter hard to push past 1/2 throttle when running
ok, you're trying to change gears when the throttle is OVER half??? <br /><br />If so, most outboards have a mechanism that locks out the gear lever when the throttle is pushed up, this is to keep the lower unit from being abused/keep one from slammin into the dock.<br /><br />I'll bet thats what is happening, you're overcoming the lockout mechanism and probably running the risk of damaging your gearset.
