  #1
Old June 28th, 2001, 09:38 AM
sonofleary sonofleary is offline
Default Sticky Electric Shifter in '69 Evinrude 85hp
Hello, We have a 1969 85 hp Evinrude outboard. For the past six years, the electric shifter hasn't been working properly. It refuses to shift from forward back to neutral 90% of the time. It will go from forward to reverse (yes, I know I shouldn't do that) every time. It will go from reverse to neutral every time, so this proves that all three switches in the control panel are working properly. The problem seems to be in the motor. But get this: it only does it when the boat is in the water. I can run the motor in the driveway for hours, and it will shift properly *every time*, and then it will immediately screw up again as soon as I put it in the water. It seems like the higher water pressure from being in the lake has some effect on it. I have taken it to two mechanics, and they both claim to have fixed it. Neither one did, and I have been thorougly ripped off twice. Have any of you encountered this problem before? Can you tell me how to fix it, or at least what to tell the next mechanic I go to? Thanks guys.
  #2
Old June 28th, 2001, 10:49 AM
Default Re: Sticky Electric Shifter in '69 Evinrude 85hp
By the way, I have some idea of how the shift solenoids in this motor work. I'm told that there are two of them. When it's in neutral, one solenoid is active; when it's in reverse, both solenoids are active; and when it's in forward, none are active. I haven't pulled the lower unit off yet; although I am a mechanical engineer, I've never done it before and I have to build up my nerve before I start yanking parts off the motor. I was just wondering what to expect as far as pulling off the lower unit, and what to look for as far as solenoids. My best guess is that the "neutral solenoid" must be bad, but I still don't understand why it would work out of the water but not in the water. Maybe because it has to work harder to unload the prop when it's under a load? I dunno. Thanks in advance.
  #3
Old June 28th, 2001, 03:01 PM
bkhine bkhine is offline
Yes there are only 2 solenoids. For more information see chat room discussions dated June22, 2001 on OMC electric shift. My problem is a little different. I have a 55 Evinrude I broke the rod that holds the plunger and solenoids. I will not go into how I did this (stupidity), but I will tell you parts are rare and if the springs are weak you will probably have to find the whole assembly. Found one used - $200. the lench of the assembly is very critical to the performance. If you have a location for parts, let me know. Good luck and take care if you remove and then re-install the assembly.
  #4
Old June 28th, 2001, 04:54 PM
dw711 dw711 is offline
this is just a guess but one of the two wires that run down the lower unit into the solenoids may be rubbed through and when the water fills the lower unit it could be causing a short. good luck
  #5
Old June 28th, 2001, 10:20 PM
hondon hondon is offline
I might also add that the type of gear oil you use is critical .OMC premium blend or another type C low viscosty oil.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1972 evinrude 85hp shifter cable replacement git-r-done Johnson & Evinrude Outboards 2 July 15th, 2005 03:16 PM
In need of a 1969 evinrude 85hp electric lower unit!!! tlawson Johnson & Evinrude Outboards 3 June 23rd, 2005 07:04 PM
72 evinrude 85hp shifter Bobk321 Johnson & Evinrude Outboards 1 March 31st, 2005 03:19 PM
1975 85hp sticky grease looking stuff coming from the stator KrisC Johnson & Evinrude Outboards 4 August 4th, 2003 12:20 PM
1968 85hp Evinrude Electric Shift not getting spark on plugs JohnD90472 Johnson & Evinrude Outboards 10 July 19th, 2001 07:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
