When I set the idle on the 9.5 it seems to change on it's own?. I mean, I get it to idle nice and smooth in neutral, then put it into gear. From there it starts to stubble a little so I give it a hair more throttle the back off it again. It idle's faster for about 30sec then drops to where I want it, then starts to pickup on it's own again. I've tried adjusting the low speed mix, within that 1/4 turn someone had suggested. But I just can't get it to idle smoothly in gear without stubbling or idling to fast. Could this be a float level issue, and if so what should the float level be. <br /><br /> I realize this engine is no spring chicken, but I can't help but feel that it could idle smoother in gear.
