  #1
Old June 25th, 2001, 11:46 AM
joeyp joeyp is offline
Default Evinrude 9.9 exhaust problem
Hey, I could use some help. After finally deciding the smoke and low idle problem on our motor was a leak in the exhaust system, my husband tried to get the old gasket off and couldn't figure out how to disconnect the linkage for the throttle and the shifter. He has performed a temporary fix with some gasket sealer that came in a tube. We will have to fix this over the winter, though. Any help we can get would be greatly appreciated. The year on the motor is a 75Thanks, joeyp
  #2
Old June 25th, 2001, 01:30 PM
tuhuna tuhuna is offline
Default Re: Evinrude 9.9 exhaust problem
joeyp, If you are removing the lower unit a coupler will reveal itself when you seperate the lower unit. The coupler connects the shift rod to the lower shift rod so that you can remove the l.u.. hope this is what your looking for. Tuhuna!
  #3
Old June 25th, 2001, 04:02 PM
kalloway kalloway is offline
I sounds like the leak has to be in between the block and lower unit and he has to pull the bottom cowling off to unbolt it. There's no gasket to leak in the lower unit. It is a pain to do and things like throttle leakage need to be kept aligned. Mark both sides as they are taken apart. You'll need a manual and/or large area to keep parts in sequence. If you put the wrong thing back on first and then find some screws that can't be gotten to later, my story, you start over. This is a good winter project. It'll take at least 4 - 8 to 16 hours based on having the manual and how many times you start over. Once it's torn down, every gasket/grommet that can be replaced should be. I had to tear down my '78 9.9 because a grommet between the waterpump tube and block had melted and would stop flow when it got hot. A $.25 part that cost me hours of grief and several head gaskets from overheating. After several years I finally found it after studying a parts manual.
  #4
Old June 27th, 2001, 10:19 AM
Thanks for your help. It sounds like we have quite a project ahead of us. First we will have to get our hands on a repair manual and then find some space. Hopefully, the temporary fix will hold for our two week vacation.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
exhaust bellow problem cryoman Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 April 18th, 2006 06:49 AM
exhaust bellow problem cryoman Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 April 12th, 2006 05:26 AM
9,5 exhaust problem henning_dt85 Johnson & Evinrude Outboards 3 September 17th, 2004 10:00 AM
exhaust problem foresteronw Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 June 13th, 2003 05:21 PM
Force exhaust problem pgattuso Force & Chrysler Outboards 3 April 30th, 2001 06:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
