40 hp oil injected 1990 Johnson OB. Soon as switch is turned on constant alarm sounds. Boat runs at 2500 rpm, normal 4000 rpm. Manual says that constant alarm is overheat. I unplug wire from float on oil reservoir and alarm silences. Unplug wire from heat sensor on motor and alarm continues. Alarm must not be from overheat sensor on motor because motor has not been started.
