I have a 200 FIcht, year model 2000. Engine has been rebuilt with new pistons, main bearings and one new rod. The engine is running great except for the voltage output. I have to keep charging my starting battery every time i come off the water. I check the voltage on my GPS and it stays around 12 to 12.4. Never increase when i give it throttle. When i put accessories on, the GPS shows the voltage dropping below 12 and then goes back up to 12 when given the throttle but never increases above 12 or 12.4. Is it the stator, voltage rectifier or some other problems. any help is appreciated.
