  #1
Old June 2nd, 2001, 09:49 PM
BMAN BMAN is offline
Default EVINRUDE 70hp still misfiring
'79 model intermittent misfiring (no spark to plug) on the top cylinder. i have put new coil on this cylinder, replaced power pack, replaced stator, replaced rectifier, checked flywheel for loose magnets and it looks ok to me. i have checked all the wiring and connections in the ignition. i put it the shop before i replaced these parts and the mechanic rebuilt the carbs. it has a one year old fuel pump. the only thing i think i haven't tried now is the timer base. anyone have any other ideas?
  #2
Old June 2nd, 2001, 11:45 PM
12Footer's Avatar
12Footer 12Footer is offline
Default Re: EVINRUDE 70hp still misfiring
It has to be the switch box,providing the plug is not dry. If it is wet, it's the coil (you replaced that) or the switch box not sending signal to coil.Look for a ground-path at the plug and plug wire also.That's about all it can be. good luck,and tight linez.
__________________
"Did you hear about the guy whose whole left side was cut off? He's all
right now."
  #3
Old June 3rd, 2001, 11:21 AM
i disabled the kill wire from the powerpack (black/yellow stripe). still not getting spark to top cylinder. is this a good test for bad switch or should i try something else? thanks
  #4
Old June 5th, 2001, 08:52 AM
still looking for help. i have a used timer base on the way to try. i hope that does it. i don't know what else to try and i can't trust my local marina. please help, thanks
  #5
Old June 6th, 2001, 11:00 AM
i rechecked all the grounds on the coils and the pack and got it to run good again. i thought it was fixed. when i got home from work (8hours later) i started it again and it was not firing again. i haven't got my used timer base in yet to try it. if that doesn't do it i give up. i'll just get rid of it. please help.
  #6
Old June 6th, 2001, 01:57 PM
12Footer's Avatar
One thing you can try before your timer base, remove the pplugs, and switch them. See if the dead cylinder follows a bad plug.Just to be sure it's not an arcing plug.
__________________
right now."
  #7
Old January 22nd, 2009, 07:03 PM
john0974 john0974 is offline
hey mate i also have a70hp envirude with same problem u sound like u have the same lazy mechanic as myself we have had coils replaced,plugs replaced,wiring checked,checked leads at nite for a spark out all timing is set fine carbie`s r all clean,has 121 compression in all cylinders,did u ever have any luck with urs mate mine motor runs fine once ur going but when idling has a misfire
  #8
Old January 22nd, 2009, 08:15 PM
CharlieB CharlieB is online now
Souonds like you have spent a lot of money on parts before learning how to troubleshoot an ignition system.
Sorry for the sarcasm, but.....
A DVA meter can be your best friend when electrical gremlins get into your motor.
CDI Ignitions have a wonderful outboard ignition troubleshooting guide posted free on their site, a copy is also somewhere here on iboats, I just don't know the correct address.
TEST, TEST, and TEST again!!!!!!!
The DVA meter will SHOW YOU (I'm in Missouri, the 'Show Me' State) which part is at fault.
Save all those old parts, many are still good and will have some value when the need arises.
  #9
Old January 22nd, 2009, 09:41 PM
tx1961whaler tx1961whaler is offline
You have resurrected an 8 year old thread. I'm sure he fixed it by now.....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude misfiring after adjusting throttle linkage Walker Johnson & Evinrude Outboards 1 July 4th, 2006 11:41 AM
misfiring cylinder evinrude 50 sea cow Johnson & Evinrude Outboards 4 October 16th, 2004 08:19 PM
misfiring 1986 140 evinrude dcolpitts Johnson & Evinrude Outboards 2 July 20th, 2003 01:59 PM
2000 Evinrude 90 Ficht misfiring DavioGradio Johnson & Evinrude Outboards 2 January 13th, 2003 05:23 AM
Evinrude 120 Misfiring framarjen Johnson & Evinrude Outboards 8 July 22nd, 2002 05:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
