Hello, I've got a couple of questions.<br /><br />First, on my last time out my motor started shutting down after 5-10 minutes at full speed. A couple of times when it started I dropped it down to idle speed and it stayed running but it usually just quit. The problem was intermittent. Sometimes it would start to lose power slowly and then go and sometimes it would never get up to full power. I was thinking fuel filter? But that's just a guess.<br /><br />Second, every once in a while the oil alarm will sound (continuous 1/2 second alarm with a half second pause). The alarm stops when I pump the bulb and the oil supply line. Oil usage seems normal but I've only had the boat for about 3 months so I don't have much to compare to.<br /><br />Finally, does anyone know where I can get a replacement oil reservoir? Mine has a very slow leak which is kind of a nuisance.<br /><br />Thanks for any help,<br /><br />Joe
