Re: Converting transom mount to cable/foot pedals
Right, cut the positive wire leading to the battery and connect the switch there. Foot-control trolling motors have a big dial on the pedal to dial in the speed, plus a switch like the one we're talking about...in your case I think unless you wanted to fabricate a dial you could operate with your foot and somehow incorporate it into your pedal, you could remove the speed control from the motor and move it to within reach, just splice in however much wire you need...or just leave it attached if you can reach it from where you're sitting.<br /><br />The switch I'm thinking of would come from an auto parts store - but it wouldn't be made for marine use - you'd have to come up with a way to keep it dry. Better yet, there's a switch on the market, called "bigfoot" or something like that, designed just for this purpose.<br /><br />Seems to me, the control cables are the hard part...I'm really impressed that you were able to work that out. sounds like a cool project...got any pics?
