  #1
Old May 23rd, 2001, 06:21 AM
bigmofish bigmofish is offline
Default spring starting problem Evinrude 115
I posted this once earlier this month. I have gone through the same steps and problems for the past 4 years. I have a 1969 115 that has not started the first outing of the year for the past 4 years. There is no spark. I start through diagnostics and by the time everything is checked out and tests okay I have fire and the engine runs fine for the balance of the season. I am at a loss and frustrated that I have to go through this every spring. Any suggestions will be appreciated.
  #2
Old May 23rd, 2001, 06:33 PM
12Footer's Avatar
12Footer 12Footer is offline
Default Re: spring starting problem Evinrude 115
You got me. But it sounds like a ignition part is rusting-up over the winter. Perhaps under the flywheel? Maybee the stator is getting a coat of rust on it ,and after turning-over enough to remove the rust, it goes.Also, try loosening then tightening all terminals you can get to,and see if it cures it..But this is just guessing out loud.Hope you get it figured out.
__________________
"Did you hear about the guy whose whole left side was cut off? He's all
right now."
  #3
Old May 23rd, 2001, 10:11 PM
I have tried all of the items you suggested. One question I have is do you think it is possible for the pick up coil to be intermittent due to a small amount of moisture getting into the sealed unit. Once I pull the flywheel it could dry out and then work ok until it sits over the winter and has enough time to take on more moisture and fail to work? I guess that is a cheap enough part I should just replace it and see what happens.
  #4
Old May 24th, 2001, 05:47 AM
nbpbborg nbpbborg is offline
After being an auto mechanic for years, I can say you are on the right track. I would bet it's moisture in a unit, due to an unsealed condition. Winters are condensation monsters. I would start at the coils and start replacing parts until she's fixed. Bad part is you won't know for sure till next winter. Either way you'll be out a fair amount of money -
  #5
Old May 24th, 2001, 06:07 AM
JB's Avatar
JB JB is offline
Yo, bigmofish. In the interest of economy, next spring before you head for the marina the first time, stick a hair dryer up under your cover for about half an hour.Bon Voyage.JB
__________________
RED SKY at night. . .
JB
  #6
Old May 24th, 2001, 09:20 AM
Thanks guys. I am going to replace the pick up coil and see what happens.
  #7
Old May 24th, 2001, 12:31 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
JB, it's interesting you bring up a hair dryer. I had a customer back then that had to "warm up" his power pack on one of those if he let it sit for more than a couple of weeks. Don't ask me how he figured that out but he did. Once he got spark back it would work fine until he let it set. Those old battery CD systems were something else. He finally sprung for a new pack and I sent the old one to the OMC training center. I always wondered what his wife's hair looked like those days.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1991 OMC Cobra 4.3 L Spring Starting...too early?? mike11374 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 April 3rd, 2007 05:26 PM
Evinrude starting problem ark Johnson & Evinrude Outboards 4 April 5th, 2004 04:17 PM
Evinrude 2hp starting problem Rdalton Johnson & Evinrude Outboards 3 May 19th, 2003 10:43 AM
Evinrude (79) 115 HP Starting Problem 115999R Johnson & Evinrude Outboards 0 May 7th, 2003 07:24 AM
Evinrude Starting Problem StuFraser Johnson & Evinrude Outboards 1 February 10th, 2002 06:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
