I know where the 2 exhaust relief holes are but i don't know about tell tell holes.It does have the two hoses at the thermostat.I was told by one shop to drill a hole in the top of the engine into the water jacket but this seems to risky to try on my own.
Was just told by a local shop that this engine does not have a tell tell hose and they could not even tell me where to put in the tap for psi gauge.It does have a water passage plate at the top of the engine, wondered if that would be a good place to tap into.Thanks to anyone with any info
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Re: 1977 Evinrude water psi gauge
Look on the water jacket plate (big bubble on rear of powerhead). Sometimes there was a boss where the fitting was later placed for the overboard indicator. Put your fitting there. The top plate will give you a false (low) reading.Good luck!
Still have not found a fitting to hook up gauge to.Was told i could use the thermostat housing to tap into,I replaced the thermostats on this engine 2 months ago and it was a big pain to do this with engine all together.Anyone have any more ideas. Thanks
The correct place is the water cover on the exhaust bubble. Drill and tap and install your fitting there. Install a fitting number 321886. Run a hose from that thru the pan to create your overboard indicator. Your water pressure line will then T into that line. That T will be in the pressure gauge kit.Good luck!
