I was checking the switches on my dash,and found running lights would not turn on, nor radio. when bilge switch turned on, the bilge then would not turn off even with the switch in the off position. I needed to disconnect the battery - even the battery cutoff switch in the off position would not kill the bilge. Next, trying to restart the boat, I got nothing except the starter spinning but not engaging. The tilt trim motor - nothing.<br /><br />Is this a ground problem, a starter problem, or something else? please help.
