MASTER Brian
- Mar 26, 2006
- 738
I recently bought a Ranger boat that a rat or something ate some of the wires in. I believe I have everything fixed except for the front depth finder. <br /><br />It's a Lowrance depth finder and the wires seem to be some sort of coaxial cable, the outside wire housing is black, with what looks like a braided wire shield that wraps completely around a clear housing another, I believe white wire. My question is how can this be repaired? Do I need to replace the entire cable or can I just splice it back together? If it can be sliced, is there a special way to do this or can I just twist the braided wire together and solder it?<br /><br />Being as this is a very basic depth finder from the late 80's I would eventually like to replace it with something more current and with better fish finding capabilities. In this case is there a more universal wire to replace it with or are all the wires fairly interchangeable?<br /><br />Another side question to this, is I believe all 3 depth finders on this boat appear to go to one transducer. Would that be correct of an '86 Ranger boat? If so how does that work? Would the wires "y" off somewhere? I just need to know what to look for.<br /><br />Thanks
