bigbassbrent
- Apr 10, 2005
- 18
I have a bottom line tournament master HR fish finder (s/n 08281284). Problem is the unit only plots 2or3 lines of data once every 15 or 20seconds...Goes on a coffee break...plots another 2 or 3 lines and then waits another 40 seconds or so for the next data to be plotted. The data recorded is correct (depth). Adjusting the graph speed setting from low medium or hi doesn't help. The boat is not traveling fast. The transducer is a through hull model. WOuld you guess the transducer is bad, or the unit. I'd love to plug in a different transducer to test this but i can't find a local dealer here in San Diego. Anyone have a best guess if the unit is shot, the transducer is shot, or if it is cheaper to just buy a new unit and transducer???<br /><br />Thanks<br />Brent
