danmcmartin
- Dec 19, 2003
- 24
I just boat a used boat with mercruider i/o. It is equiped with an alternator and that is hooked up to the starting battery, theoretically. I haven't verified. I took it out for the first time today and it ran great. When I picked it up the previous owner stated he hadn't taken it out in a few weeks or charged it. Since it started fine in my driveway I figured it had enough juice. When I started it at the ramp it was a little sluggish but fired up and then we ran it for about 30 to 45 minutes out on the lake. Fortunatly, I didn't shut it off until I was near the ramp. When I tried to fire it back up the battery was dead. I used the trolling motor hooked up to the other batteries to get to the ramp and to lift the outdrive. <br /><br />I was showing about 12 volts before starting and about 13 or 14 while running. Now it it shows about 9. Shouldn't the starting motor have charged while running? If I could start it at the ramp and it charged while running it should have been fine. What would make it discharge? Bad battery? Bad alternator, regulator or maybe wiring? Amy ideas to get me started would help.
