  #1
Old December 26th, 2000, 04:37 AM
Jimbo 2962 Jimbo 2962 is offline
Default Water/Oil spraying out Exhaust Evinrude
Hi friends, Merry Christmas. Unfortunatly I noticed water and oil spraying out the exhaust on my 120 hp Evinrude. It has been running rough at low speed (like fouled plug) but fine at high speed. This power head rebuilt 50 hrs. Will take a compression test today. Any ideas of what the problem may be?Thanks Jim
  #2
Old December 26th, 2000, 08:25 AM
C Hawk C Hawk is offline
Default Re: Water/Oil spraying out Exhaust Evinrude
I would re-torque head bolts,and if that didn't work I would check head gasket. C Hawk
  #3
Old December 26th, 2000, 12:18 PM
Thanks CHawk. Did compression check. Cyl 1-130, #2-129, #3-130, #4-132. That would indicate Head gasket good..right?Jim
  #4
Old December 26th, 2000, 07:26 PM
I would check compression with hot motor. I had motor with crack in cylinder wall showed good compression cold. Hope it's not that. C Hawk
  #5
Old December 27th, 2000, 04:53 AM
C Hawk, I ran the motor for about 3 min.. before doing compression check. At least it was warm. The motor has finished DOUBLE oil break-in awhile back (rebuilt power head). Could it be from ac***alation of oil or or a high concentration of oil still in tank. The motor has a VRO. Have been told to check that.
  #6
Old December 27th, 2000, 06:40 AM
Capt DHD Capt DHD is offline
Hello Jimbo;I think the engine you have is a thirsty one.If it is a 90* V-4 Looper, I guess I am not all that surprised with a little oil & fuel comming from the exhaust into the water. I will assume this is the type engine you have in my comments.4 carbs, very fickle, not all that easy to dial in. First, clean the grounds to each of your coils, make sure they are making a solid contact. Test the engine before doing anything else. A bad ground could cause intermitant fire to one or more cylinders creating your problem.If the problem still exists;Look for a differance in one of the plugs, you may need to make a slight adjustment to the carb that feeds that cylinder only. Each carb should have it's own low speed needle. Each carb low speed needle adjustment may not end up being exactly the same. (should be close but not nessisarally exact) make minor adjustsments, retest engine, use a bit of paitence and don't do anything radical.Your compression sounds good, I believe your problem is minor.Good Luck, Rob
  #7
Old December 27th, 2000, 10:10 AM
Thanks Rob. I have contacted a mechanic. When he comes by I will mention these things to him and let you know the results.Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Water spraying from block inmar 5.7 v8 ross_larter Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 6th, 2005 09:32 AM
water spraying from heat exchanger end cap skiMachine Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 April 15th, 2005 02:53 PM
Water spraying for the top spark plug. rc92370 Mercury & Mariner Outboards 8 August 5th, 2003 08:00 AM
Water keeps spraying me in the face. trollhole Stupid Human Tricks While Boating/Fishing 7 January 31st, 2003 09:09 PM
tell tale water spraying not streaming tenacrewoods Honda & Tohatsu/Nissan Outboards 3 June 20th, 2002 04:55 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
