Re: Bilge Pump wiring/switch
The reasoning behind my original question was; if a short occurs in a hot (red) wire, the fuse will blow, or burn up the wiring between the short and the + side of the battery. By minimizing the length of run of the + wire, I reduce the "short" possibility. I realize there will be some, even marginal at best, voltage drop over 20 to 22 ft of wire, regardless of + or - lead. My concern was, why chance burning up a + wire 22' long when a chafe in a ground wire run that length would not cause a short. Also, let me clarify my original post. I still have my fuse block at the console. I am adding a fuse block (2 fuses)from my common on the Battery Selector Switch on the transom to power my 2 bilge pumps separtely. Each would then have their own separate ground lead to a switch on the console, then to the ground buss. I see a similar type of arrangement on my Yamaha outboard 175. The lead to power the remote oil tank pump is hot with key on. The Oil control Unit controls the pump operation by grounding and causing the pump to turn on. The indicator lights on the tach for the oil unit are also controlled this way. 1 hot wire splits to 3; green, yellow, and red. The Oil control Unit then grounds out the appropriate light for indication. I figured, if it works for Yamaha, then why not my bilge pump. If there is going to be a "chance" of a short, why not reduce the length of hot wiring. If a ground wire chafes, I doubt it would complete the circuit back to the battery on a f/g boat.<br />These are just my thoughts and nothing set in stone yet. Plan to wire up the engine and starting circuits this weekend.
