  #1
Old January 26th, 2002, 11:54 AM
cw72648 cw72648 is offline
Default Rewind Spring Replacement Evinrude 4
My l976 evinrude 4 rewind sping broke, I purchaced a replacement, but am now hesitate (scared) about installing it without some guidenance.
  #2
Old January 26th, 2002, 09:58 PM
DJ DJ is offline
Default Re: Rewind Spring Replacement Evinrude 4
rweaver,I believe this is the type in which the starter rope turns a gear that that inturn rotates the flywheel? Are the parts plastic?Are you sure the spring is broken?
  #3
Old January 27th, 2002, 03:16 AM
JB's Avatar
JB JB is offline
Hi, RWeaver. You are correct to be scared of that li'l monster!Once while rehabbing a small OMC that had been swimming I took the recoil starter apart, including releasing (I couldn't call it removing) the recoil spring to fly about and scare the heck out of me.Putting it back took several hours and would have made a hilarious video. I tried at least a dozen ways that didn't work before I hit on hooking the center to the "tub" that holds the spring, then winding it on about 5 or 6 inches at a time. You can't imagine the relief I felt when the outer end slipped into the tub and hooked onto it's stud.Wear safety glasses, gloves and a long sleeved shirt. Bring plenty of patience with you when you set at it. It can be done.Maybe someone else knows an easy way to do it. None of my manuals gives the first clue other than saying something like "reinstall the recoil spring". Yeah, big help.Good luck, you have a real challenge ahead.Red sky at night. . .JB
__________________
RED SKY at night. . .
JB
  #4
Old January 27th, 2002, 06:47 AM
Backlash Backlash is offline
Hey Guys,There is no easy way to install it. JB did it the only way I know of. Backlash
  #5
Old January 27th, 2002, 08:06 AM
DJ DJ is offline
Kind of like trying to stuff a mad wet cat into a bag.
  #6
Old January 27th, 2002, 04:23 PM
Thanks to all for your insight, I was hopeing for a easy solution, will try winding it on tommorrow.
  #7
Old January 28th, 2002, 02:54 PM
Hopefully this will be my last post on this subjuct. Thanks to J. B. Cornwell, your way worked very well.
  #8
Old August 31st, 2008, 09:48 PM
leor leor is offline
I'm far from and expert, but I've had a few round with these things and found a way of assembling them that works for me. I'm glad that no one has videoed me working on these springs, or recorded my comments when they got lively.
I've had my best luck by winding the spring flat on the bench and then clamping a vice grip at one place on an inside and outside edge of the coiled spring to hold it together. Then there's a process of firmly holding it down, releasing the vice grip, pulling it tighter and clamping it again a number of times until it fits into the back piece of the recoil unit with the vice grips attached and the outside retaining loop over the notch. Finally, with some care, I release the clamp and notch the the plastic pulley in place on the middle loop, slide in the bolt that holds it on walk very carefully over to the engine.
Well, it works for me.
  #9
Old August 31st, 2008, 10:50 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Assemble the manual starter to the engine, having the inner sping loop inserted over the related pin, BUT leave the starter spring UNWOUND and simply hanging thru the slot of the manual starter housing with the long length of the spring out side of the manual starter.
Now, using ingenuity, force that plastic gear up into the flywheel teeth, jamming it so that it will stay engaged in those teeth.
It is now simply a matter of putting a wrench on the flywheel nut and turning it in the proper direction to pull that spring into the manual starter housing which will properly rewind it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Spring Rewind Assembly for 1975 Mercury 40HP jasonjanise Mercury & Mariner Outboards 1 July 17th, 2006 10:00 PM
rewind spring for 9.5 evinrude firecapt561 Johnson & Evinrude Outboards 2 April 18th, 2005 08:45 PM
5.5 Evinrude Drive Shaft Spring Replacement K Hultgre Johnson & Evinrude Outboards 13 June 8th, 2004 09:54 AM
recoil spring replacement on 9.5hp Evinrude frankbn Johnson & Evinrude Outboards 4 April 30th, 2003 12:13 AM
REWIND SPRING FOR 65 9.5 HP EVINRUDE R.GEORGE Johnson & Evinrude Outboards 3 March 7th, 2003 06:49 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
