My '86 Evinrude 140 kept hesitating/stalling as it was accelerated. Occationally you could get it to WOT and it would run fine once there.
I took all four carb barrels off, cleaned, replaced gaskets, replaced needle valves, adjusted floats, replaced one jet that was different than the manual suggests. Afterward it accelerated fine right up to WOT, but it only lasted about 10 minutes. Thereafter, each time I accelerated the hesitation/stalling problem got worse until I was back where I started.
Any thoughts??
Thanks.
