Re: Adding Second Battery Need Long Cables
I would put all positive leads on the switch, except maybe an auto bilge pump; I want the entire electrical system shut down when the switch is "off", but that's just me.<br /><br />That being said, what ever is connected directly to a battery (or terminal 1/2 on the switch) will only operate off that battery. What ever is connected to the "common" switch terminal will operate on which ever battery is selected by the switch. Assuming the motor positive lead is connected to "common", the motor will charge which ever battery is selected by the switch (or both).<br /><br />The alternator wires are designed to disconnect the "field" before the switch hits the "off" position, which saves it from damage. It should be connected as indicated by the two battery-one engine switch diagram. Alternately (no pun), don't ever place the switch to "off" with the motor running.
