Check compression, should all be within 10 or 15 from each other. How much not as important, as long as they are close to each other.
Check outdrive oil for chunks and color. Shavings ok if you cant feel them, no creamy oil or grayish color.
I would also look around motor for things unplugged. Wanna make sure warning bell is hooked up!
Keep VRO, i like them. With these simple steps taken, and if it sounds and runs solid, it should be ok! Happy Thanksgiving!
