Evinrude 4 hp, '92, 2-stroke, twincylinder, one gear
I've replaced sparkplugs, cables, breakers, one of faulty coils. Carburateur looks OK. Engine stops as desires, sometimes starts after it other times lets me sweat a lot. Sometimes goes fine on 0.75% rpm quite long but refuses to start when stopped. I am not going to give up on him. Please help.
Re: Evinrude 4 hp, '92, 2-stroke, twincylinder, one gear
Hi Marian, Welcome to the list...Next time you have a problem check if the primer bulb is hard.. I think you have a fuel issue...see if pumping it when running allows you to reach WOT (wide open throttle)... if it does, then you have a problem with your fuel pump or lines, (or the primer bulb itself.)I also think it would be a good idea to strip and clean the carbs...regardsFrank.
Thanks for Your answer,Frank. I forgot to mention that it runs on a small tank on top of it. Anyway, I'll try to concentrate on fuel system. Have a nice day.Thanks again, Marian
