Re: MINN KOTA MODEL 65C TROLLING MOTOR
Anyway what a great conversation this turned out to be. I always thought the word thrust was to put into motion and not the amount of amps it consumes. That link was interesting to say the least. I have a motorguid 43 LB thrust and on high it only uses 2.5 AMPS, I use a high grade amp meter in series solely because Im setting it up for a solar powered boat. I was thinking of using three trolling motors all about 50 LBS thrust and the combination of the three should draw about 9 to 10 amps per hour. So on a six hour fishing day the motors would probably run about 2 hours total. I would then need to replace about 20 amps to keep the batteries to a full charge. Anyway just having some fun with it to pass the time away.
