Re: Transom Mount Transducer
Many will work this way but you need to expect a certain performance (sensitivity) loss as the ultrasound is now partially absorbed in the hull during transmit and again on receive. Several of the mfrs that I have seen show both methods of mounting the transducer in the installation instructions. Whichever type transducer is used, you must be very careful not to get ANY bubbles in the epoxy potting compound between the tranducer and hull.
