  #1
Old July 10th, 2003, 09:40 AM
zj-jeepster zj-jeepster is offline
Default 1974 Evinrude 85HP V4 shifting noise
my 1974 V4 Evinrude 85HP is working well now except when shifting into either forward or reverse it makes noises until fully engaged. it goes "gala gala klunk" then everything is smooth. it actuall shakes a bit when it "klunks" then all is well. fluid old or hardware problem? thanks.
  #2
Old July 10th, 2003, 09:44 AM
JasonB JasonB is offline
Default Re: 1974 Evinrude 85HP V4 shifting noise
I would change the fluid as these motors have an oil pump that helps the shift. My 76 cleared up some noise this way when I first got it.
  #3
Old July 10th, 2003, 09:58 AM
papasage papasage is offline
donot ease the shifter in gear . push in gear quick.
  #4
Old July 10th, 2003, 10:39 AM
thanks guys,it's docked at the marina now so I'll have to haul it out and take a closer look at the fluid condition.yeh, I've read some where that it should be shifted briskly. I'm not aware of my shifting habbits so I'll check on that too.will try to post back on results, hopefully within a couple weeks.
  #5
Old July 19th, 2003, 11:54 AM
this old post found a new home, yehhh ok, i remember the last time i worked on the prop that i only tightened the prop nut hand tight and the holes didn't line up so i actually backed it off to line up the hole so i could get the cotter pin in. this done 'cause at the time i didn't have a wrench with me. come to think of it the previous owner did the samething so i just took the prop off without a wrench.this time i tightened down the prop with a wrench so it's nice and tight against the thrust washer or what ever and now the "klunck" and the initial shake is gone. itt still goes "gala gala" for just an instant but i'm glad that annoying klunck is gone.just wanted to post back on what's going on. hope this helps anyone.
  #6
Old July 19th, 2003, 03:43 PM
Hooty Hooty is offline
Thanks for bring us up to speed on what the fix was, Jeepster. Wish everybody would do that. c/6Hooty
  #7
Old July 19th, 2003, 04:45 PM
the prop was so loose on the shaft that i could actually move it back and forth on the shaft. my guess is that as soon as it goes in gear, with idle speed around 500 rpm, the prop spins up instantly and hits hard enough to cause that "klunk"Hooty,thanks for the encouragement. i think some folks asks questions then either got the problem fixed and forgot to post back or, worst case senario, they just give up and sell their rig.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1974 85hp Evinrude timer base problem? supafly1232 Johnson & Evinrude Outboards 7 July 6th, 2004 04:30 PM
Shifting on a 76 85HP Evinrude spiderjohn Johnson & Evinrude Outboards 6 April 8th, 2004 03:27 PM
1974 Evinrude 85HP V4 shifting noise zj-jeepster Johnson & Evinrude Outboards 3 July 10th, 2003 10:39 AM
1974 Evinrude 85hp bogs down when accelerating. rgrish Johnson & Evinrude Outboards 4 July 28th, 2002 06:37 PM
Shifting problems-85HP Evinrude campjung Johnson & Evinrude Outboards 2 July 27th, 2002 08:34 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
