Up to what speed should you fishfinder function?
tonyscj5
Up to what speed does your fish finder work?<br /><br />How and when is it nessecary to adjust the transducer. When installing it give instruction to adjust. But I installed and it works, but I am unsure how well it is working. It reads up to about 5 or 6 miles/hour.<br /><br />thanks
billwpg
Re: Up to what speed should you fishfinder function?
For what it is worth mine works to about 10-15 mph before it starts to "flash" the last recorded depth since it has lost its bottom signal. The transducer needs to be mounted in a place where it gets as much water as possible as you are driving. That is, closer to the edge of your boat than the motor, and just above the bottom. All boats are differnt and it helps to play with the location a bit to optimize (I know I could do better if I played a bit but it is fine for how I use it). Best if you have a seperate mounting plate that allows you to move it around to find the best position without drilling new holes in your hull each time!
Stumpys
For what it's worth... I was told to put it on high speed scroll while driving at higher speeds. So far it works fine until I go over 15 mph.<br /><br />Of course the high dollar works work better, but I just use my Hummingbird depth finder for high speeds.
Boatist
Mine works good to 25 and not bad out to 30. One brand that seemed no one got to work over trolling speed.<br /><br />You boat and instalation most important. If you have a aluminum boat with rivets you will need to mount deep. Many bass boats have a place to mount a shoot thru hull transducer and will work to over 50. Transducer must be below the air coming off the hull, be pointed straight down or maybe 1 or 2 degrees foward. The transduce instlation is everything. It must be mounted in clean green water at the speed you want to use it.<br />That one brand a year or so back it did not seem to matter what you did, only worked up to trolling speed.
imported_JD__
I assume you're asking, at what speed can you still get a bottom reading? Mine will maintain bottom lock @ 45 + MPH. If I go into a hard turn at that speed it will momentarily loose the bottom but once I'm running straight ahead it regains lock. My 'ducer is mounted so its face is 1/2"-3/4" below the hull and approximately 12 inches from the centerline.<br />JD
dingbat
I'm with JD here. I'm using an in-hull transducer submerged in an oil bath. Works just fine at WOT @ 40+ MPH.
ThomWV
How fast can a car go?<br /><br />Its really about the same sort of question and just like the one you asked, it has no answer. There is a maximum speed the boat could go, in a specific depth of water, at which it could not function, but that is purely a matter of the speed of sound in water and the boat's ability to outpace the returning echo from an outgoing ping produced by the transducer. I have calculated that speed a couple of times and the absolute number is very high, much higher than any of our boats will go. The deeper the water the slower the absolute speed you can read. So the problem of a failed reading is not one of boat speed, its something else.<br /><br />As Boatits said, the problem lies in the mounting or in the hull configuration, but in each case it is related to the flow of water over the face of the transducer or the hull below where the transducer is located if the thing happens to be in-hull mounted.<br /><br />Because of its incompressability water is a very good medium for sound to travel through. Air, on the other hand, provides a much less dense medium for the transmission of sound waves. So if you have constant contact between the transducer face and the water you get the best sound transmissio characteristics. On the other hand if you introduce air into the water that is flowing over the face of the transducer or if for some reason a bubble forms over the face of the transducer then the ability of the transducer to put out pings into the water or to receive echos back from the bottom is greatly reduced.<br /><br />So, where to bubbles come from? Well, as Boatist said, from rivits, from strakes, from thru hulls ahead of the transducer, and sometimes just from a poorly designed hull that foams up the water a lot. That is the hull side of things. Then there is the design of the transducer itself. Some of them are simply shapped poorly and create their own bubble-mess as they are pulled through the water. Of course there is the mountying style of the transducer to contend with as well.<br /><br />While we often think of transducers as commin in basically three styles; In-Hull, Thru-Hull, and Trnasom Mount, in fact the actual transducer element that is used in each of the three is often the same between models made or sold by any given fish finder manufacturer, and many times between manufacturers as well. As you may already know a single company, Airmar, makes the vast majority of transducers used on small boats all over the world - and most of those used on larger boats too for that matter. There are a few off the wall companys that make their own, folks like Humminbird and Lowrance, but in fact Airmar even makes transducers that can be used with those company's machines if you want to buy them. My point is that inside the transducer the same elements and circuitry are used and so the performance of one is very much like the other. The outside cases vary a bit and that is often the cause of speed reading problems, but the transducer itself is reall probably the same no matter who made it, within reason.<br /><br />Of course where and how the transducer is mounted matters a lot. If the transducer is mounted so that its face is always covered with a smooth flow of water and it is also pointed straight down, or slightly forward of down, it is going to work at any speed you can go. That is why true thru-hull transducers work so well. They are mounted on the outside of the hull, on its bottom, and they enjoy constant immersion. On the other hand if you mount a transducer to the transom the first thing you run into is a little space between the back of the boat and the face of the transducer and you have some sorts of bracket holding everything in place, and some sort of adjusting scheme to allow you to compensate for the shape of the transom and all of that stuff adds up to bubble makers when you get going at some speed or another. That simply means that with a transom mount at some speed you will get bubbles and when that happens the transducer will quit working.<br /><br />The third method of mounting a transducer is to put it inside the hull. With this system the sound passes through the hull material and into the water as does the return echo. If the flow of water is smooth and not filled with air directly under the mounting location these transducers will operate well. Of course there is a basic problem with this sort of mounting. That is that there is power loss passing through the glass and some difusion of the concentration of the outgoing signal (roughly equal to an incresase in the much-misunderstood "cone angle") but it is of little importance.<br /><br />So basically the bottom line is that in-hulls will work at the fastest speeds, thru-hulls are next best, and transom mounts are the worst when it comes to speed. Its all a matter of mounting of course and what you have to do is find a place with clean water to get one to work well. After that its a matter of adjustment to make sure its shooting straight down, or slightly forward of straight down, when the boat is at its running attitude.<br /><br />As to the absolute question of speed, well that vaires from one hull to another and transducer type. As as example I've gone through several different transducers on our boat along with several different fish finders. The fish finder I use (Furuno 582L) is probably one of the the more sensitive small boat fish finder made and it has very sophisticated software for interpreting return signals. It also has plenty of power so in any water up to a couple of thousand feet it is not limited in its ability to read on that front. <br /><br />For about a year I used a standard thru hull trasducer with it, the Furuno model 520ST-MSD, which is a bronze depth/speed/temperature unit. I used it with a standard fairing block and a great deal of attention was paid to getting it exactly level when it was mounted. That transducer/fish finder combination was good for speeds up to about 30 knots on nice days, less when it was bumpy, considerably less when we were getting our eye-teeth knocked out. I removed that transducer last winter and glassed the hole it passed through shut. I then ground out a section of the glass in my hull's bottom and reglassed it to insure that there were no voids in my glasswork and mounted a new in-hull transducer (Airmar M-260) in essentially the same spot as the old thru-hull had been mounted. This mounting was right on the center line of our 23' boat, situated about 3~4 feet forward of the transom. That mounting location corresponds with the smoothest flow of water under my hull. That transducer will not loose bottom because of any speed my boat is capable of going. My maximum speed is 38 knots (43.7 mph). That is not to say that the fish finder will not loose bottom at lower speed. If we are in water greater than about 1,500~2,000 feet it will loose bottom at lower speed, but that is a function of power, not transducer type or placement.<br /><br />So, does that help answer your question? The speed you read is a matter of transducer type, mounting location in terms of a smooth flow of water over its face, quality of mounting in terms of being pointed straight down, and finally the relationship of depth to speed.<br /><br />By the way, if you are interested in one of the high performance transducers for a small fish finder the M-260, and its thru-hull cousin the B-260, are as good as it gets. They are quite large and they have a maximum input power of 1 kW, but if you want the ultimate in fish finder performace they are the transducer you want. They are available to connect to many different makes and models of fish finder. Be prepared for sticker shock though. The B-260, which is the thru-hull model is expensive and you will want to use the high speed fairing block with it. In the in-hull, M-260, version it will come with a mounting tank that you will cut to match the interior of your hull and then seal in place with 5200. The tank is filled with mineral oil and the transducer is supspended within the tank. This outfit isn't cheap by any stretch of the immagination, and in fact costs about $100 more than the bronze thru-hull version. For the money you get to look at the bottom at any speed you want to go and you get to do it with a clairity unmatched by any other transducer. Each of these two transducers uses a single large element (about 50% larger than the standard transducer) for its high frequency operation and 7 smaller elements for high frequency. This is in comparison to a single smaller element doing dual duty for standard transducers.<br /><br />Thom<br /><br />Oh, just for comparison, just to give you an idea of the size, here is a picture of the M-260 and its mounting tank next to a standard thru-hull transducer. The 260 is the big black blob, the mounting tank is the yellow thing. That stainless steel plate is what holds the transducer in place at the top of the tank. In the foreground (because its closer to the camera it looks a lot larger than it really is) is the standard bronze thru-hull:<br /><br />
mattttt25
to summarize our friend thom, you need clean water!<br /><br />may have said it in another post, but boating mag did a great article last month on the types of transducers and their performance. they did a great test- took a boat out to sea with three transducers installed- thru-hull, in-hull, and transom mounted. one color fishfinder. no test of speed, but they cruised around structures at a slow speed and took input from all three transducers. performance was apparent in the pictures they provided- the thru-hull worked best, followed by the transom mount, and finally in-hull. good read.
tonyscj5
Thanks all very much for the replies, that could possibly be the most information about fish finders I have ever heard, and definetly the most succsessful forum post in my net history. <br /><br />I now understand hte problem, but the answer is not so clear. Could I set up my hummingbird for a through hull set up? Maybe make a box and fill it with oil, then mount the transducer in that?<br /><br />Or it would probably be easier to mount or adjust the transducer on the hull. Any advice on adjusting it, I tried to find the most turbulence free area on the transome. I do have dual outboards, so lots of water is churned by them. How is the center line of the boat, right on the tip of the V? <br /><br />Please help me fix this problem. It is a pain to have to stop and check depth, just to find the fishing grounds.<br /><br />thanks<br />Tony<br /><br />PS-I just remembered a through hull set up probably wont work, because my transducer has a temp sensor on it that I need for tuna fishing, I imagine it needs to be submerged at all times.
imported_JD__
Tony,<br />Yes, The "V' is what we are referring to as centerline. The idea is to get the transducer as close to the "V" as possible but not so close as to pick up turbulence/bubbles generated by the prop(s). As you are aware, at rest your boat sits much deeper in the water than when you plane out. The idea is to make sure your transducer's face is still in the water (non-turbulent water) when you are under way. Since the "V" remains in the water at all speeds (unless you're airborne), the closer you mount the 'ducer to centerline, the more likely it will be running underwater at higher speeds. Transducer location isn't the only consideration, overall quality of the unit is equally important. I don't know what you have but you could be trying to exceed the capability of your unit. Do yourself a favor and read the installation guide at http://www.lowrance.com/support/installation_guide.asp <br />This will apply to about any manufacturer's product, not just Lowrance.<br />JD
