I have a 1998 22' Stingray 4.3L mercruiser. The gas guage works fine then it will peg out either way past full or way past empty. Then it appears the needle is actually stuck. I pull the guage form the dash and can pry a screwdriver in the face of the guage and it releases the needle and the guage will work fine. Then it will happen again. What can be causing this "pegging" of the needle. My guess is something electrical but I have cleaned the connections and checked the wiring. The only thing I have checked is removing the wires from the sending unit and cleaning. Its just odd that it works fine for hours and then happens then I fix it and it works fine..then it happens again.
