Re: Charging 24v trolling batteries from outboard
It can be done. First, you have to know the difference between series and parallel. Series is positive to negative, which is adds voltage. This is how you get 24V from two 12V for your trolling motor. Parallel is positive to positive, and negative to negative. <br /><br />If you have them all hooked in parallel, you can charge the whole bank at once. I recommend isolators to avoid any danger from differing voltages.<br /><br />Now, on that note, your motor is not the best way to charge a deep cycle battery. They like to be slow charged a certain way for maximum efficiency and life. So, yes it is possible to charge all three batteries from your motor, but it's not the "best" way.<br /><br />I can't give you specifics on how much it will affect your battery life. It may be nearly insignificant, or it may have a severe impact. But rest assured, it WILL have an impact.
