  #1
Old September 11th, 2005, 08:52 PM
craige1982 craige1982 is offline
Default Wiring diagram to solve problem on Mercury Outboard
Hi all. I have a 40HP Mercury Outboard (approx 98 model) which I have just put on a boat with a Quicksilver control box, and I have a problem where it will start fine however it will not turn off when I turn the key off. The only way to stop it is pull the leads from the spark plug. There is a blk/yel wire which when connected will stop sparks getting to the plugs, howver this will prevent the sparks weather the key is on or off. Does anyone have a wiring diagram for the 40HP outboard, or the quicksilver control box? Any help would be greatly appreciated. Thanks
  #2
Old September 12th, 2005, 04:10 PM
cbcrawford cbcrawford is offline
Default Re: Wiring diagram to solve problem on Mercury Outboard
You should post this in mercs . . . but I'd avoid asking for the diagram, just ask for help. Some of the moderators (rightly) get upset when you ask for material that is obtained commercialy.First thing you should buy with any boat is a manual for the outboard, it'll have the diagrams for the controls in it.CC
  #3
Old September 13th, 2005, 06:30 AM
Pickels Pickels is offline
Sounds like you have power to the boat 100% of the time - and the only thing your key switch is doing is engaging the starter.Easy to test this if your motor has a rope pull starter on it. When the motor is not running and with the key removed - pull the rope starter and see if it will run. If it does -- it will be simple to find out whether you have a defective switch (use a volt/ohm meter).
  #4
Old September 15th, 2005, 04:17 PM
joblo33 joblo33 is offline
BTW, unplugging the plug wires while running will wreck your coils. Use the choke to kill it in that situation.Eric
  #5
Old September 16th, 2005, 03:38 PM
TELMANMN TELMANMN is offline
Here in the states I would go to a public library and get a schematic. I do not know if that is available down under. I have a 98 merc. book but it is up at my cabin and I will not be up there till next week. As previous post said, just choke it too quite or pull gas line.
  #6
Old September 17th, 2005, 06:47 AM
Moody Blue Moody Blue is offline
Are you able to stop the motor using the kill switch ? If not, then the problem is likely that you have a bad ground in the kill circuit within the control box.
  #7
Old September 30th, 2005, 03:24 PM
JohnRuff JohnRuff is offline
Did you find the answer?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Force Outboard 120HP Wiring Diagram CSwart Force & Chrysler Outboards 2 March 21st, 2009 07:33 PM
Wiring Diagram for a 92 50 hp Mercury Outboard Srnpittsb Mercury & Mariner Outboards 1 October 11th, 2006 08:18 PM
Wiring Diagram for a 1977 Chrylser Outboard rlongxr7 Force & Chrysler Outboards 1 July 31st, 2005 08:54 AM
!990 115 merc outboard wiring diagram jjoediv Mercury & Mariner Outboards 2 July 17th, 2005 02:51 PM
Wiring Diagram 55hp Evinrude Outboard Eicher Johnson & Evinrude Outboards 2 March 10th, 2004 09:27 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
