  #1
Old July 19th, 2004, 06:40 AM
astewart astewart is offline
Default Purchasing new boat, need advice.
Ok i'm looking for a used starter "value" boat that my family of 3 can use for fish and ski. I found a nice boat for what I think is a good price that I might want to check out however there's no fishing amenities that I can see. Can I install a captains chair in the front for fishing or is that something that just isn't done?Also if you look at the picture can anyone tell me if thats an oil leak below the motor? http://adcache.boattraderonline.com/6/3/5/74304435.htm Thanks,Allan..
  #2
Old July 19th, 2004, 07:02 AM
Chris1956 Chris1956 is offline
Default Re: Purchasing new boat, need advice.
Astewart, The boat looks pretty clean and the price seems good. Due to its lack of bottom paint,I will assume it was run in a lake or trailered, which also is a plus.The oil leak (if it is oil) is unusual, since it is not coming from the outdrive. It appears to come from the bilge of the boat via the drainplug. It is likely power trim fluid or power steering fluid or engine oil. You should look for the source of the leak. Replacement hoses for the power trim system are $50 each, power steering hoses $125/set.The boat itself is a good choice for all around family fun. You will be able to fish and water ski. It will prove to be a bit under powered with the 4 cylinder motor, however. Expect 35-38MPH as top speed. Also, it will prove to be a bit small in the interior, since a 17 footer is small to have a sterndrive motor. It will prove to be good on gas, but periodic maintenance is high on a sterndrive, and very high ($1000/year) if you have it professionally maintained. Repairs will also need to be made, in addition to periodic maintenance.You can certainly put a captains chair in front. It may cut down on the interior space, and eliminate one seat, however it is done frequently. You will need to use some anchor-type fasteners to hold the chair in place!
  #3
Old July 19th, 2004, 07:30 AM
Thanks for the advice. One last question. Can I hook up a trolling motor and fish finder finder to that boat?Thanks,Allan..
  #4
Old July 19th, 2004, 07:47 AM
jajeeper jajeeper is offline
It looks like there is a pretty good gash on the side. I can't tell for sure, but it looks like the front may have some bangs on it as well. If this post last long enough you will hear allot of negative info about Bayliner brands.
  #5
Old July 19th, 2004, 08:11 AM
SpinnerBait_Nut's Avatar
SpinnerBait_Nut SpinnerBait_Nut is offline
A true iboats friend
Quote:
Originally posted by astewart: Ok i'm looking for a used starter "value" boat that my family of 3 can use for fish and ski.
Why not just get you a fish and ski boat?For the money you will spend on this one plus the extra $'s for adding what you want, you can get a good F&S boat.Just my .02 worth.P.S. Even a regular bass boat can be used to pull skiers with.
__________________
http://banners.wunderground.com/weat...tlettsburg.gif
http://www.frappr.com/iboats
"JUST KEEP ON, KEEPING ON"©
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
  #6
Old July 19th, 2004, 08:42 AM
When you say fish and ski do you mean something like the Bayliner with the fish and ski option? I was looking at used boats so I haven't seen all thats out there because most websites only show the new ones and alot of sales don't have pictures so it's not that helpful for a beginner like myself.Are there a few modals I can look for that is similar to the Bayliner with fish and ski?
  #7
Old July 19th, 2004, 08:45 AM
Go to the Boating Classifieds section of this website and check out the fish and ski section to see what's available: http://www.iboats.com/boats/marine--...i_boats--1099/ There are a bunch of used boats with multiple pictures.
  #8
Old July 19th, 2004, 09:20 AM
roscoe's Avatar
roscoe roscoe is offline
In my opinion, you are better off getting a fishing boat and using it for skiing. Fiberglass bowriders are difficult to fish from. There is little if any open space to store rods, coolers, tackleboxes, landing nets, etc. The sides are high and thick, the seats are low, and the seats take up most of the space so you can't get close to the water to land fish.Something like this: http://www.fisherboats.com/index.cfm...v=29&boat=1168
  #9
Old July 19th, 2004, 09:30 AM
Bert1 Bert1 is offline
Astewart, I have a Capri 160 and I was able to add a platform and a swivell chair to the bow section of mine. Here is what it involved;1. On mine the bow cushions are snap in, so easily removable. First step is to remove the two cushions.2. Create a template (using cardboard or heavy paper) of the entire bow area. This should be a triangular shape and covers the space usually covered by the cushions as well as the walking space (Leave 1/2 inch space all around).3. Use this template to cut out a 3/4 inch tick piece of plywood (marine grade). 4. Cover the plywood with carpet (To match interior of boat)5. Find where to and locate some felt tabs underneat wherever there is a resting spot (contact between the board and the fiberglass of the boat).6. Find a pedestall and swiveling seat and install in the middle of the platform. 7. Achor the whole unit to the boat using heavy bungie cords. I placed 4 O rings underneat that hang in the underseat storage compartment. I then tie the bungies in a ''X'' pattern underneat. THe left and right side communicate with each other.This may sound complicated, but it took me a couple of hours to complete, cost about $100.00 and I have been using it for four years without any problems. When we go fishing I put it in, when we go cruising/skying/tubing, I remove it and put the cushions in.Hope this helps.
  #10
Old July 19th, 2004, 11:51 AM
1kickpic 1kickpic is offline
i agree with roscoe...the most important part of a fishing boat is the interior space. that's why, on a "bass tracker" style boat, three guys can walk around easily with all that equipment. but, a boat that is say 18', hi-sided, with a walk-thru windshield (no wasted space in the bow) can operate perfectly for both fishing and water skiing. your two front seats could be single captain style chairs, but your rear seats should be made for economy of space and be more functional than comfortable. go outboard, not i/b or i/o, again, more space.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Glasply I/O Ski Boat--Any advice before purchasing? Once bit, twice shy! cheburashka Glasply 2 May 17th, 2006 11:34 PM
advice needed for purchasing a ski boat davejnz Boat Topics and Questions (not engine topics) 11 June 20th, 2005 01:56 PM
Looking at purchasing a used boat, need some advice Belchy Boat Topics and Questions (not engine topics) 3 April 21st, 2005 03:26 PM
purchasing boat advice firemom Non-Repair Outboard Discussions 3 October 14th, 2003 06:12 AM
Need advice on purchasing boat musictrek Boat Topics and Questions (not engine topics) 5 September 3rd, 2001 07:24 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
