I am replacing the 12V 43lb. motor guide on my 18' aluminum bassboat. The 43lb.is efficient if the water is calm, but on semi-rough days, its a battle in 5th speed to try to hang in. I am looking at Motor Guide's 54lb. 12 volt motor. This appears to be max. in a 12V. Will going this large in 12V. severely shorten run time off a 12V battery? I know to jump up to 24V. would probably be the way to go, but to make room for another battery would be a problem. Plus, I don't want to replace 2 deep cycle batteries every 3 or 4 years instead of one. Any thoughts?
