Re: Charging voltage Mariner / Yamaha 55 EL
Jurgens, I am not sure what kind of charging system you have on that motor (regulated or not). On an unregulated system, as the RPMs rise, the current output from the stator/rectifier-based charging system rise. The voltage will rise slightly also. As the battery reaches full charge, the voltage on the system will rise to about 13.5V. The difference in voltage between the battery and the charging system is proportional to the charging current.
