GLUEING TEAK SCREWHEAD PLUGS
dmarkvid2
I will be making 3/8 teak plugs to insert into counterbored holes, to cover screwheads. Is it better to use a wood glue, or is 5200 adheisive sealer better? I want to be able to remove them if I had to.
flashback
Re: GLUEING TEAK SCREWHEAD PLUGS
I just use varnish. haven't had a problem yet, but I varnish the wood also...yea I know I'm a masochist.. :D
dmarkvid2
Its not a good idea to varnish teak wood. The oil bleeds right through.
tashasdaddy
after 35 years of fine carpentry, use elmers white glue, and immediately clean any excess with damp rag. this will not leave a glue mark on the surrounding wood. then oil or varnish.
dmarkvid2
I know Elmers makes wood glue, I'll go with that. Thanks guys.
