I'm about to refasten my deck/hull and I have rivets and washers. I have the largest rivets I can get without a special riveting tool. The boat has been taken apart before and the lip of the deck and hull are full of holes. I'd like to use the same holes that I drilled the rivets out of, but I'm afraid that the rivets won't catch. I have washers for the rivets, but I don't really want to spend a couple of hours up under the deck (small boat) holding washers on while someone else rivets. I've contemplated having a piece of thin sheet metal bent into a "v" and slipping it over the lip on the hull before reassembling. There should be enough room to fit something the thickness of residential flashing. Probably even thicker. My worries are that this will keep the sealant from glueing the two halves of the boat together. Even if I goup the inside and outside, metal isn't as good a surface for adhesion as the rough fibreglass. <br /><br />I also don't really want to do fibreglass work all along the edge of the hull.<br /><br />Anyone have any thoughts, comments, or experience on this?<br /><br />Thank You.
