Rick K
- Oct 6, 2003
- 235
Hi again all,<br /><br />No doubt you've seen my tantrum post on doing thigs right the first time. When I pulled the water seperator from my transom, there was a rot spot. Not a big deal; I can patch with epoxy/cabosil/mat, and move on with life.<br /><br />NOW, I see that the entire top of the transom is rotted, about 3-4" down. When I bought the boat, I stabbed the transom no fewer than 50,000 times to see that it was solid. I know it's my fault for not going up high enough, and I'll live with the expense and labor of fixing her. It's not a problem; it keeps me off the streets, and the wife knows where I am!!!<br /><br />I pulled the rubrail and popped the rivets off the deck, to expose the top of the transom. Here's what I found: Some STOOGE had decided that the rubail was lose, so they screwed in 3"-#14 screws right thru it, into the transom. Also, there was no sealer behind the aluminum rubrail channel, which leads me to believe it was off and not reinstalled properly. Then, the top skin was a bit loose, so it was NAILED into place, then covered back up with the rubrail. Tisk, Tisk, Tisk.... <br /><br />So, I will effect the following repair: Remove 6" of transom along the entire top. Make a replacement piece, using 2pcs 3/4" plywood, epoxy, fiber matt, etc. Install. Cut another piece, only higher, which will cover that, and extend down over the existing transom. <br /><br />Tie it all together, etc., then go back thru the hull with the proper fasteners, sealing everything in my path. Then, using a 3"x3" aluminum angle, I'll cap the outside, where the transom and deck meet, and go thru the hull, install rubrail, enjoy. I think this method will aleviate any unecessary or unwanted flex, PLUS, will strengthen the deck to transom joint.<br /><br />The alternative, of course, is to remove the engine and outdrive, and install a whole new transom. Not a problem, but I'm not that schooled in outdrives, and don't see myself trying to reinstall it once it's out. <br /><br />Opinions? Advice?<br />Thanks!
