Thank you for your help! To answer your question, since then, stringers and deck have been fiberglassed. and the deck Is comming along, But won't be in the water till '07 unfortunately.
Rick, I was looking at your Islander, another nice boat in the making. I read where you wanted to remove the boats name lettering. You can use a heat gun as long as the letters are made of vinyl. The heat should loosen them up good enough to scrape them off. Then use a glue disolver to loose the clue. Just make sure its ok on fiberglass. Oh, one more thing, before you go ahead and rename her, make sure you go through the renaming ritual to apease Neptune, or else you'll have bad luck the entire time you own the boat. Here is the website for that. VERY IMPORTANT!! http://www.boatsafe.com/nauticalknowhow/rename.htm
