  #1
Old July 18th, 2004, 02:25 PM
Scooch_2 Scooch_2 is offline
Default Aluminum boat and ground wire
I have an older 17 foot aluminum boat with a small console and a 35HP Mercury. There is a compartment under where I sit that has the battery and gas tank. There is a ground wire that is attached to the frame of the boat that goes to the battery. The boat spends most of its time in fresh water at the dock behind my house. From what I have read, I believe it is probably a bad idea to have the negative terminal of the battery hooked up to the hull. Should I disconnect and remove it or continue to use it. Why would it be setup that way in the first place?
  #2
Old July 18th, 2004, 03:16 PM
mercbob mercbob is offline
Default Re: Aluminum boat and ground wire
any time you have power going to anything you need to ground that power out so it is not able to run all over the place. it would be a good idea if you could find a place on the motor block to run your ground to if not it will be fine where it is
  #3
Old July 23rd, 2004, 07:13 PM
Ben Konopacky Ben Konopacky is offline
most likely your eng.mtg.is grounded to the boats hull ,so it would not be isolated from the batt.in the first place,the grd. wire is ok..
  #4
Old July 23rd, 2004, 07:14 PM
Sorry..
  #5
Old July 24th, 2004, 04:10 PM
walleyehed's Avatar
walleyehed walleyehed is offline
If you have a metal fuel tank, it's quite possible that the wire goes from the boat to the tank...not the batt.
  #6
Old July 25th, 2004, 01:41 PM
crab bait crab bait is offline
i never heard/knew it was 'bad' to do so.. like to know why..
  #7
Old July 25th, 2004, 01:58 PM
kcole683 kcole683 is offline
If you are worried about it run a seperate wire from the engine block. Electricity will take the path of least resistance anyway. Your hull is almost certainly grounded very well already through the engine mounting, as it should be.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Which is the ground wire? gap705 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 11th, 2004 06:53 AM
ground wire getting warm dennisrhall Mercury & Mariner Outboards 10 April 5th, 2004 10:24 PM
Can I run the Ground wire through the switch? imported_Warren Electrics, Electronics and Trolling Motors 5 April 4th, 2004 03:44 PM
hot ground wire prider11 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 April 9th, 2003 07:03 AM
Ground Wire? steelespike Yamaha & Suzuki Outboards 2 July 23rd, 2002 04:32 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
