where to find wiring harnesses and wiring diagrams
nick.wright
Hi all,<br /><br /> My boat 16' Galaxy needs to be seriously rewired. Where can I find OEM wiring harnesses and a wiring diagram???
Re: where to find wiring harnesses and wiring diagrams
You probably Won't find Either 1.......<br /><br />The New wiring harness you can Build yourself,......
KaGee
Originally posted by nwright:<br /> Hi all,<br /><br /> My boat 16' Galaxy needs to be seriously rewired. Where can I find OEM wiring harnesses and a wiring diagram???
You do not list your powerplant. Outboard? I/O?Motor Harnesses are OEM specific i.e. Merc, OMC, etc. The boat manufacturer will use what is supplied by the motor OEM.<br /><br />Wiring diagrams are normally found in the service manual for the powerplant involved.<br /><br />If you are looking for wiring info for the hull, i.e. lights, horn, bilge pump etc., Like Bondo said... they don't exist
nick.wright
Keith,<br /> 4 cy mercruiser I/O. What I need to the diagram for the 9 pin plug that goes to the engine. I think I have found new plugs, and looking for a manual also.
nick.wright
SWEET!!!! Thats what I'm looking for.
