Re: any tips on spraying varnish?
Look into hot varnishing,it's by far superior to shooting a cold finish.If your new to this type of thing id suggest you go down to your nearest paint only store and see if they rent airless sprayers. If you use one make sure it has not been put away wet (junk).Ask them advise on what type of tips to use and if they respond intelligently stay with them. Putting on a air finish is by far easier and far superior than one might guess, just never stop the gun when your fanning a peiece always finsh the stroke. With a little practice you will see how much your applying in one swipe,notice if there are any sags or is it to thin, then adjust accordingly(speed of the fanning) until you get the desired application. When you have that down time for the real thing.
