victorjohn
- Jun 22, 2004
- 6
Let me preface my posting by saying that I am not an employee of Nauticus. Nor am I related to or being paid by them. The reason I say this is because I'm probably going to sound like a commercial. I have a 10 foot Livingston which is a catamaran style fiberglass dinghy with a very heavy 15hp Tohatsu 4-stroke with tiller handle on the stern. I had such a bow-high attitude with this configuration that I thought it would be impossible to correct. After researching some, I came across Nauticus and their smart tabs that were designed with my sized boat and power plant in mind. The tabs have nitrogen gas filled actuators attached that sense water pressure and move the tabs accordingly and automatically. With my weight and the weight of the OB in back, I thought they might help but had no idea how much. The results were astonishing. My first test drive with these tabs had me reeling. I couldn't believe it. The boat got right up on to a plane and manuevered itself in way that was perfectly straight and level. It still blows me away. They were fairly easy to install. I'm an accountant, so if I can put them on, anyone can. I would highly recommend these tabs. They make them in different sizes with larger pressured actuators for larger boats too. They truly are amazing. Trust me, if you have any kind of stability or bow-high pitch problems, these tabs will cure your problem.
