Bayou Dave
- Dec 13, 2012
- 1,780
I noticed today that the starboard motor mount is not tightened down properly.
The boat has run great all summer with no vibration.
Apparently the bottom adjusting nut is locked in but the top nut is nowhere near tight. The port side looks normal. I am going to change the starter and need to jack up the engine a little as the starter is wedged against the wood base that the motor mount attaches to.
It looks like I have a good inch of play on the motor mount threads and that amount will give me more than enough space to slide the starter forward.
Will it change the alignment of the motor just by using a bar to jack up the motor on that side by 1/2 to one inch and letting it back down to the existing position?
I would tighten the top nut after I get the new starter in.
