I have a25hp merc that just stopped dead when I was going about half speed Then I stated it and it idled rough but ran smooth at high speed I have rebuilt the carb and replace all ign componants The bottom cylinder has spark but when I pull the wire off the RPM doesnt change The comprssion on both cyl is 130psi. I'm at a loss to figure this out The bottom plug is wet with gas but has good spark the reed valve looks good Any suggestions?
