Rivergator
- May 7, 2013
- 218
I actually have 2 problems. When the engine is running a tiny amount of oil leaks through the center bolts on both sides of the intake manifold. I tightened up the bolts slightly and the leak stopped on one side but still trickles up on the other side. I don't see any water in the oil. What is the meaning of this? Is there a small leak at the gasket under my intake manifold or is it just where the bolts are? The other problem is a little bigger. I haven't had the boat in the water all summer because of some serious repairs that needed to be done to my steering. This is all done now and I am getting ready to launch the boat. I am test running my engine and the engine runs just fine as long as I keep it above 1000 rpm but it stalls, it dies when throttling back to idle. Last year it was idling just fine. What has gone wrong? Could it be the old gas, even though I treated it at the end of last years season, a possible vacuum leak, or is it a carb problem?
