ontarioboater69
- Sep 21, 2013
- 1
Hi to all, this is my first posting, as well my first boat I'm looking to buy.
Allow me to start off with I'm green when it comes to boats, but that said I have rebuild cars from the ground up.
I have an opportunity to buy a 1988 Bayliner Ciera 2455 for about $1500.00. It hasn't been in the water for about 2 or 3 years. but the motor does run. As for the outdrive, it's not on the boat right now but he has it. The fuse panel is unscrewed and some wires are disconnected. There seem to be a wet spot on the carpet between the fuse panel and the bed that runs under the stairs. The pump that runs the rams to raise and lower the sterndrive is missing, so I'll have to buy a new one. The "L" bench is weathered and cracked.
I guess my big concern is if I buy it and there is a problem with the hull (sinking) is it something that would fixable. With that said, I went all over the hull looking for cracks, dings or anything like that and I couldn't see anything wrong.
It's only $1500.00, what would be a reasonable amount to put in the boat, all in all it looked pretty good to me, but what do I know
