while changing leg oil in a Yamaha V6-4.3 unit and using a refilling lube kit/pump from Evinrude/Johnson is there a difference in thread size at the bottom plug not allowing the pump unit to connect? If so, can the leg be filled by slowly pumping new oil in through the top plug without any problems? B.
